im running the same head with prw's im impressed with the quailty..not done with the build...just checking what cam are you running?
the rocker arm ration increases the lift of you cam..it should state a lift with a certin rocker arm ratio..lets say 1.5 if you go 1.6 the lift will increase.....but im no expert
