An accurate 8 3/4" rear axle width list
Transmission and Drivetrain Tech
  1. STRorange
    STRorange Well-Known Member
    72
    67
    Mar 31, 2018
    Isle of Sheeps, UK
    Local Time:
    10:53 AM
    Great Axle chart, just one that's not quite right though.
    65-69 C-Body axle housing is very close to E-body at 56 1/2" not 56 3/4" as listed.
    Very easy to mix up as they are almost identical, C's 1/6'' of an inch wider than E's overall.
    Got two of each kind here, so I have checked them VERY carefully lol:rofl:
  2. dukeboy_318
    dukeboy_318 FABO Gold Member FABO Gold Member
    43,548
    19330
    Jan 19, 2007
    No
    Local Time:
    5:53 AM
    @72bluNblu i know this is an OLD thread I'm digging up here, but is the pinion perfectly centered in the rear axle on the A body 8.75 or is it offset to one side or the other a tad?
  3. 66fs
    66fs FABO Gold Member FABO Gold Member
    5,605
    2165
    Sep 9, 2009
    Greenwood, South Carolina
    Local Time:
    5:53 AM
    Offset but axles are the same length
    • Like Like x 1
    • Agree Agree x 1
    • dukeboy_318
      43,548
      19330
      Jan 19, 2007
      No
      Local Time:
      5:53 AM
      nevermind, if the axles are the same length, I guess it doesn't matter
      • Agree Agree x 1
      • 66fs
        5,605
        2165
        Sep 9, 2009
        Local Time:
        5:53 AM
        DrDiff has a nice calculator. You can get a good feel for 8 3/4 rear dimensions. 1 3/16" offset from the calculator
        DoctorDiff Housing/Axle Calculator
        Enjoy
        • Thanks! Thanks! x 1
        • Agree Agree x 1
        • dukeboy_318
          43,548
          19330
          Jan 19, 2007
          No
          Local Time:
          5:53 AM
          thanks!
        • hellfirechrome
          hellfirechrome Well-Known Member
          353
          25
          Aug 7, 2009
          Tahoe
          Local Time:
          2:53 AM
          I’m about to have an eight and three-quarter inch axle professionally narrowed. Is the 52 5/8 inch measurement “flange to flange”, for my early barracuda, the measurement between the flange backs or flange centers? I’ve seen it stated both ways.
        • 72bluNblu
          72bluNblu FABO Gold Member FABO Gold Member
          11,566
          6251
          Nov 28, 2008
          NorCal
          Local Time:
          2:53 AM
          Outside to outside on the housing flanges. And that’s just the bare housing, no backing plates or anything.
        • hellfirechrome
          353
          25
          Aug 7, 2009
          Tahoe
          Local Time:
          2:53 AM
          Killer. Thank you!!! Came home with three housings, might get 'em all cut!
        • Jeff 63ValiantConvertible
          Jeff 63ValiantConvertible Active Member
          27
          1
          Oct 13, 2019
          Virginia
          Local Time:
          5:53 AM
          Do you have any information for an A Body 1963 Plymouth Valiant Signet. I am wanting to upgrade from /6 to a 318 and it is recommended that I change the rear to 8 3/4...I have no idea just what I need to make this change...do you know?
        • abodyjoe
          abodyjoe Well-Known Member
          21,640
          7421
          May 22, 2004
          Berlin,N.J. 08009
          Local Time:
          5:53 AM
          you need the abody 8 3/4, the 8 3/4 shock plates and the right length drive shaft.
          27
          1
          Oct 13, 2019
          Virginia
          Local Time:
          5:53 AM
          Thanks for the reply:
          I saw that the 8 3/4 listed here had various lengths, unfortunately my year and body type were t included. Question, are all the 8 3/4 axels for A Bodies the same length?
          Also, my car came with a 904 for /6 if Infind a sb 904, do I have to change the drive shaft?
          Thank You
        • 72bluNblu
          11,566
          6251
          Nov 28, 2008
          NorCal
          Local Time:
          2:53 AM
          All A-body 8 3/4’s are the same width. And /6 904’s and small block 904’s are the same length. So the length of the driveshaft still has to change going to the 8 3/4.
          27
          1
          Oct 13, 2019
          Virginia
          Local Time:
          5:53 AM
          have you ever done a slant 6 V8 Swap?
        • 72bluNblu
          11,566
          6251
          Nov 28, 2008
          NorCal
          Local Time:
          2:53 AM
          Yes, for my ‘74 Duster. It went from a slant6/904/7.25 to a 318/904/7.25 to a 340/833/8.75 and is currently a 340/T56/8.75.
          27
          1
          Oct 13, 2019
          Virginia
          Local Time:
          5:53 AM
          I have some questions, would you mind answering some?
        • 72bluNblu
          11,566
          6251
          Nov 28, 2008
          NorCal
          Local Time:
          2:53 AM
          Not at all, feel free to send me a message
        • pomonamissel
          pomonamissel Well-Known Member
          1,978
          1039
          May 21, 2015
          san jose , ca
          Local Time:
          4:53 AM
          thanks . pm
        • crackedback
          crackedback FABO Gold Member FABO Gold Member
          18,905
          3343
          Aug 7, 2005
          92201
          Local Time:
          2:53 AM
          I have a pretty cool spreadsheet I set up that will help with axle lengths and wheel backspace. Minitubbed or not, spring relocation both shackle and into frame. It's for A body cars, 67-75. I didn't have a early A to measure off of.
          • Like Like x 2
            27
            1
            Oct 13, 2019
            Virginia
            Local Time:
            5:53 AM
            Thank You for responding, I just can’t find much information for 63’s...I have to find out which 8.75 will work for my swap and also how many splines it should have.
            27
            1
            Oct 13, 2019
            Virginia
            Local Time:
            5:53 AM
            Thank You abodyjpe, just saw your post...how do you determine splines and what gears would you recommend for 318
          • abodyjoe
            21,640
            7421
            May 22, 2004
            Berlin,N.J. 08009
            Local Time:
            5:53 AM
            Spline? Axle splines? Pretty sure all the common year non race are the same. I forget the count to tell ya the truth.
            As for gears it all depends what you are doing. Stock 318 and just a driver I'd say 2:76-2:94.
            More then stock 318 and just around town maybe a 3:23-3:55. All depends on your combo and intended use.
            27
            1
            Oct 13, 2019
            Virginia
            Local Time:
            5:53 AM
            i wasn’t sure if I’ll need a 28 or 30 spline and didn’t know if I needed a certain year for upgrading the rear end since 63 Valiant didn’t come with a 8.75.
            My 318 build is going to have budget high performance, So would you recommend the 3.55 gears because I would like to drive to various car shows as well as around town.
            Thanks for your help.
            Jeff
          • crackedback
            18,905
            3343
            Aug 7, 2005
            92201
            Local Time:
            2:53 AM
            Any of the pumpkins should all be 30 spline axles. There isn't any other set up in passenger cars. The best fit is an A body rear if everything is stock set up. Housings aren't cheap in that variant.
          • abodyjoe
            21,640
            7421
            May 22, 2004
            Berlin,N.J. 08009
            Local Time:
            5:53 AM
            That's all personal preference.
