Krooser
Building Chinese Free Engines since 1959...
'06 Ram. Ran good...computer issue. 170k on the clock.
May be the basis for my next build.
$100.00Cool! Cheap, if I may ask?
WHOA!$100.00
Well this one needs a bit more than an ECM...
Guy told me it quit and wouldn't crank....this might be why
I have the pan off...even that was interesting as the pan is pretty much glued to the windage tray and the oil pickup is bolted thru the tray to the pump ( still new at these Gen III's).Years ago.. when I locked up a Porsche 944.. had to pull the pan and loosen all the main bearing caps to get a crank to turn so I could undo the torque tube coupler... THAT was a big job.
maybe pull the pan and loosen things up? should turn eventually.
I was just watchin a youtube video this week of a hellcat piston doin the same exact thing!
Ouch!
I welded a socket into a box end wrench, to get at the bolts, i would have to go look at what i did, or take a picture. I will say it worked well. Had to replace a seized one about 5 years ago.Block is ok...just a couple nicks in the bottom of the cylinder. Crank needs at least one journal repaired.
I think this was a lubrication problem not unlike what I saw in my sbm... No oil to the rod bearing...got hot...tossed one rod and damaged another.
I can't get it to turn over so it's been a struggle to disassemble. I need to get the torque convertor off so I can get it on an engine stand.
After I got six pistons out and the main caps off I got it to turn enough to get at the last two rod caps.I welded a socket into a box end wrench, to get at the bolts, i would have to go look at what i did, or take a picture. I will say it worked well. Had to replace a seized one about 5 years ago.
I bought an 07 srt8 Cherokee that the guy said he was on the highway and it just quit so he got it pulled over and called a tow truck to take it home.After I got six pistons out and the main caps off I got it to turn enough to get at the last two rod caps.
But it still turns hard...need a big pipe wedged in the damper
Makes me think the cam bearings are seized. Might have to get out a bmfh to get that out...out to the shop soon.
