carls72dart
hey Fabo, in need of your help. I just ordered the 60779 Eddie heads for my 340. My question is, is the Howard's cam I have, too big for stock Eddies? Here are the cam specs:
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:2,600-6,200
Intake Duration at 050 inch Lift:230
Exhaust Duration at 050 inch Lift:236
Duration at 050 inch Lift:230 int./236 exh.
Advertised Intake Duration:277
Advertised Exhaust Duration:283
Advertised Duration:277 int./283 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.531 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.547 in.
Valve Lift with Factory Rocker Arm Ratio:0.531 int./0.547 exh.
Lobe Separation (degrees):110
Computer-Controlled Compatible:No
Valve Springs Required:Yes
Camshaft Manufacturers Description:Lopey idle, strong midrange. Good throttle response, 2,400+ stall.
The 340 is .30 over forged Pistons, 273 adjustable rockers.
Thank you in advance!
