Cope
Fusing with fire
Im still working on that dam 59 GMC pick up.
I got the front signals working by fixing the ground.
Now the problem is iat the rear.
When i press on the brake pedal the flasher stops flashing and all i have is break lights.
Some how the break lights are over riding the turn signals.
The rear lights are 2 wire.
I have a dedicated turn wire to each light that is new.
A wire that is running lights.
And the break light wire.
Some how i need to go 3 into 2 wires but no matter how i wire it i cant have turn signals and brake lights at the same time.
Any ideas would be a huge help.
I realise its not an A boddy but you folks are smartest folks around so i figured id ask here.
Thanks in advance.
Thanks in advance.
