Hi guys
I'm running out of ideas here. I have a 68 Barracuda, with what seems to be the Variable speed wiper switch with push-in washer function (when I use the switch, i can push on it, I can rotate it with an "off" position, a first "on" position, and then I can keep rotating it as I wish until what seems to be a "max speed" position.
I have completely redone my wiring as it was total garbage, and this is the only thing I can't get to work.
The old wiper motor is in the picture below :
Here is my wiper switch, with how it's wired in (I used both my owner's manual and Passion4Mopars website info to wire this in, as well as matching the old wires that were already there from the original harness)
One of the connectors is unused on the wiper switch, which according to Passion 4 Mopars, is normal.
Where I run into a problem is on the wiper motor itself, which I replaced with a Cardone remanufactured item (i've heard good and bad stuff about these but, well, that's about the only thing available out there under 500$...).
The wiper motor is part number 40-350, which according to the manufacturer and Summit, fits my car.
However, nowhere online can I find any schematics of how to wire it in ... Even Passion 4 Mopars has some info, but that's not very clear to me with "A", "P", "F1", "F2" etc...
I tried a few different wire position but nothing seems to work. It's not rotation, not going into park, not getting crazy fast... well it's doing nothing basically ...
So here is the question(s) : is this the correct wiper motor for my switch?
How should it be wired??
Thanks a lot, hopefully somebody here has done this before and will be able to help because I've been scratching my head for a few days...
