If I could get my money back from Addco I'd buy one of Dave's and get some sleep. Here is a copy of the pics & notes I sent to Addco today.....
Hello John,
I have some info regarding the fitting to the 1969 Plymouth Valiant. The car was levelled and the front lower control were set to the factory alignment height. Anti-Sway bar installed as per instructions with the correct link spacing mocked up. I used the outer edge of the drag link as a datum and a chart on the floor with a plum bob. With the the vertical spacing of 2 1/2" between the bottom of the upper link mount bracket and the top of the anti-sway bar mount location. The horizontal distance between the between the upper & lower link bolt holes is 1 7/8" @ 53.13 degrees and a distance of about 3.13". That's excessive and out side the 20 dgree you mentioned
You mentioned on the phone that it should be around 20 degree. I calculated on my car 53.13 degree.
What can be done? I think either a different upper mounting bracket for the link or it's location. Or new angles and length of the anti-sway bar itself.
Please advise ASAP what ADDCO can do.
Thank you,
Brad Allore
