Nice run! looks fun.
72bluNblu, What are the advantages of going with the QA1 tubular lower control arms?
There's some truth there. That's getting between the devil and the deep blue sea. Always beware of the allure of highest speed when seeking to retain speed. When road racing, highest speed through and out of the turns usually equals best lap times. In some tighter track corners, and most autocrosses, retaining speed is good, but cutting distance reduces lap time. Figuring out and managing the balance of those two (retaining speed, and reducing distance) in real time is a learning curve for sure!looks like you could use up a little more real estate in order to retain some of your speed in a few of the corners.
Question.....Would dropped spindles be a help or a hinderence in this situation?
I have a '64 Valiant (V8/4spd) I'm collecting parts for right now. I have offset bushings, new ball joints, tie rod ends, etc., I want the car to set low but still be a decent ride. It's a semi DD/weekend autocross car. 17in wheel/tires for now. What are good shocks for this type of setup? Would the 1.03's TB's be a good choice for this one?
I am running Hotchkis Racing springs in the back. The car felt fairly balanced, with a nice amount of rotation from the rear. I will definitely run at a higher setting on the shocks next time though. I did have an issue with the fuel splashing out. The rubber on my fuel cap is pretty hard. Do they make a new seal that can replace it?69wacuda. Nice run. What rear suspension setup do you have. Looks like it handles great in the corners. So are you hooked. Corner carving is a blast I love it. Did you have problems with fuel splashing out the filler tube.
4.10:1 with an A518. I had it in 2nd (1st/2nd) on this course.69wacuda what gears are you running.
I believe this was an intentionally easy course with only a basic layout for those who maybe hadn't participated before. I will hopefully get on some more challenging courses in the near future.View attachment 1715195296This was at my first race could not get video to upload. We don’t get a lot straights to build up speed like that.
I have found nothing that works. I am looking for a lockable gas cap that goes under the flip top they are pricey. I usually make my runs in 2nd gear also.Do they make a new seal that can replace it?
Logan’s Cuda, do you run a mustang 8.8. I ask as I have one in my car and I am curious if you have bleed the rear calipers. I get very little fluid out during bleeding. Also with the firm feel springs can you get them set for height as in lower than stock height.
Just got this note via e-mail:Autocross this Sunday, Aug 4 at Wells Fargo Center (Hockey Stadium) Phila. Pa.
If anyone in the area is interested stop by, or register if you want to run.
Either way you'll have to sign a participant waiver when you enter the lots. But non-driving participants are not charged any fee.
Philly Region 2019 Summer Series Event #8
Those are some good numbers you got there. That’s impressive. Those bmw and Miatas have leed times usually. If you say you need to hug the cones more I’m thinking you can definitely shave off a couple secondsGreat event!
Got a coffee mug. LOL.
First time in a while someone has posted pics.
I'm not on FB. Anyone can look at the page.
There's a slalom gif.
Philadelphia Region SCCA
The tail of my car should be a little closer the cones.
I haven't looked through to see what the deal is on copying and pasting. Direct link to photos here:
edit: Wells Fargo Center - Solo#8
Final Results
In the gif it looks like 5 to 7 inches between the back tire and the last real slalom cone. What looks like the last cone in the images is really not a part of the slalom but I do think I should have been a bit closer.Those are some good numbers you got there. That’s impressive. Those bmw and Miatas have leed times usually. If you say you need to hug the cones more I’m thinking you can definitely shave off a couple seconds
