Plym 67,
Don't you think it is strange that
all 16 lifters could be faulty???? I don't think they are. I described earlier in this thread that the engine might need to be running to pump oil up top. I suspect all the lifters pumped up when you primed the engine. See the pic below, it is an original lifter out of a 1971 Pontiac 455 block.
The black dot on the flat disk is carbon build up,
not a hole. The underside of the PR socket is slightly rounded, as per the drawing. On the disk, you can clearly see the shiny area around the carbon dot. It was
sealing off the hole in the prod socket. Oil pressure enters the chamber & pressurises in all directions, pushing the disc up against the PR seat; blocking the hole, no oil flow....No oil flow
until a gap appears between the disc & the socket...which will happen as the lifter bleeds down slightly passing over the cam lobe.
The lifter design that uses the 4 hole disc. I have some of these. Work on exactly the same principle [ bleed down ]. The underside of the PR seat is flat. The none of the 4 holes in the disc line up with the hole in the PR skt. Oil pressure enters the chamber, & forces the disc against the PR skt. No oil flow into PR seat. The purpose of the 4 holes is so that once a gap appears, the oil pressure can enter via the 4 holes & allows oil to get to the hole in the PR seat.
Solid lifters that oil through the PR: shake them, they rattle. The rattle is the clearance of the met disc & PR seat moving around. A small gap for oil flow. These
would pump oil up to the top without the engine running.
