Ironracer
Gearhead
Damn, smoked the bands?Yeah, My brother bought Type A at the dollar store for 50 cents a quart on clearance.
Said "What will it hurt ? " It did..
Is this true? I can run standard hydraulic fluid? I’ve heard this before.Type F is just standard hydraulic fluid with a red die added.
I have heard Stocker Drag Racers run only 1 quart of 30W in the rear. Maybe ??
My understanding is Type F has a better friction coefficient. Dextron has friction modifiers for softer shifts.Does anybody know if the friction modifiers in type F have any adverse effect on lockup torque convertors?[/QUOTE
My understanding is Type F has a better friction coefficient. Dextrin has friction modifiers to allow slippage, and softer shifts
Correct, but does type F have an adverse effect on lockup convertors?My understanding is Type F has a better friction coefficient. Dextron has friction modifiers for softer shifts.
I do not know any one who has tried it personally, but my guess would be that the lockup engagement would be more aggressive.Correct, but does type F have an adverse effect on lockup convertors?
A torqueflite will run just fine on 30 weight motor oil. They just don't care.Is this true? I can run standard hydraulic fluid? I’ve heard this before.
The discussion is only about using Ford type F in a torqueflite. If you want to run "any type ATF" in your Barracuda, have at it. That's on you.Does this discussion mean I can use any type ATF in my Barracuda? If so, why do manufacturers recommend specific types? I've always been very careful to use the manufacturer's recommended ATF.
dextron III THATSALL U SHOULD RUN IN A O;DER MOPAR TRANYMan I wish we had one of these stores locally. View attachment 1715886592
NoDoes this discussion mean I can use any type ATF in my Barracuda?
Because they design the transmission to act a certain way. The ATF has a certain characteristics to it and it’s part of the overall design. Soft shifts for the passenger car and trucks.If so, why do manufacturers recommend specific types?
Then your in good shape. Street machines and racers will use the type F for reasons described above. If you have a well hopped up engine and your looking for a firmer shift while under a WOT application, then the type F will help.I've always been very careful to use the manufacturer's recommended ATF.
I’ve never heard of that. I really don’t have much to add to automatic transmission discussions. But that could be! I’ve been a manual trans guy most of my life. The only automatic trans I ever did anything to was a 904 with the MP shift improved kit. I’ve had to mix transmission fluids before. No choice at the time. No issues from it ether.Hey Rob, I bet you have heard of Old Guy transmission shops doing rebuilds recommend 1 quart of 30 WT non detergent motor oil. I've been doing that for 40+years.Old wives tale ?
Woops ! SHIRT ? Maybe on a busty babe !a tighter firmer shirt with the F fluid
OK! But I don’t want this to turn into a babe thread W/transmissions!Woops ! SHIRT ? Maybe on a busty babe !
