MOPAROFFICIAL
Oogliboogli
Rod ratioIn the bold.... huh? Say what? Mean what?
Small as necessary for the big average numbers. Besides, if something's fkd up I have a hair more room to fix it .Are you saying that because of the 185cc intake chamber???
And the SM site has no flow numbers
I am going to try to order a set of bare heads tomorrow. If I get a set I will put a set of my Edelbrock valves in them and flow test them. I will then port one intake port and give flow numbers after several mods. Valve job, Open pinch, straighten common wall, chamber work, short side widening, etc. I will also post some air speed numbers
Flow Data @ 28″ water
lift 200 300 400 500 600 700
Int 142 202 251 278 284 286
Ext 124 159 190 203 219 231
Pro max shocker 185ccYOU THE MAN!
Air speed number will be GREAT, and thank you in advance!
What head do these flow number belong to?
Is there flow number out there for the shocker?
Claims 285 but is there a full lift swing of the port somewheres?
Thanks man! Pictures included?I am going to try to order a set of bare heads tomorrow. If I get a set I will put a set of my Edelbrock valves in them and flow test them. I will then port one intake port and give flow numbers after several mods. Valve job, Open pinch, straighten common wall, chamber work, short side widening, etc. I will also post some air speed numbers
Needless to say extremely interested...I am going to try to order a set of bare heads tomorrow. If I get a set I will put a set of my Edelbrock valves in them and flow test them. I will then port one intake port and give flow numbers after several mods. Valve job, Open pinch, straighten common wall, chamber work, short side widening, etc. I will also post some air speed numbers
I'm confused, maybe, but I think those #'s are for the CNC ported SM's posted by another member, I think. lolOf course PRH just posted numbers 4 unported heads on one of the other three threads that's going on these heads right now... ..
STOP THINKING! You're going to get us all in trouble.....I'm confused, maybe, but I think those #'s are for the CNC ported SM's posted by another member, I think. lol
Nice!. I was thinking of getting a bare set of non cnc heads to see what they could be become on a budget-is that what you are doing or are you getting the cnc?I am going to try to order a set of bare heads tomorrow. If I get a set I will put a set of my Edelbrock valves in them and flow test them. I will then port one intake port and give flow numbers after several mods. Valve job, Open pinch, straighten common wall, chamber work, short side widening, etc. I will also post some air speed numbers
I'm a thinking man, the rest of you, well...………. lolSTOP THINKING! You're going to get us all in trouble.....
