demon seed
The Original Demon Seed
Gentleman, and you know who you are, my finger is poised directly above the delete button and another one is above the infraction button so move along quietly.
I run a small shop.I own a brake lathe and have never had a problem machining a drilled or slotted or factory rotor....If I have the adapter to chuck it up to my lathe,you got a machined rotor.
Lathe cuts from the sides,when spinning and feeds out from inside of rotor surface to the very outer surface,when the bit that is cutting the surface hits a hole or slot it cuts nothing until it get past that then continues to cut............
Machining a slotted, grooved or drilled rotor is no problem.
TXDart
Is there anyone out there that makes GOOD cross drilled and slotted rotors for big bolt pattern A-bodies? Also, how about good pads? I am thinking of putting them on my 73 340 Dart.
Thanks, Jeremy
TXDart
TXDart
Question, does anyone know if there is a reasonably priced 4 Piston Caliper that will bolt right on? It would only be natural to replace the stockers and put the new Rotors to some good use.
I do not think it would be worth adapting.You want the rotor to be spinning and set your cutting bits at just touching the rotor and then set the feed motor to start feed out.If That makes any sense...Is there a way to use this to turn down a rotor? Some kind of attachment or some thing? Be nice if I could if I had to. Thanks.
Sorry demon seed.
Seeing your machine and the pulley setup only the top spins.
Man, You probably can make some neat stuff with that.
What have you made with it?
Just make something for someone that has a brake lathe and trade...
Most shops and auto parts around here charge $15.00 a rotor.
Martin
I installed slotted and cross drilled rotors on the front and the back of my Dart. More for looks than anything. I just contacted Master Power who I bought my brakes from and spoke with their tech line. They have never heard of any of their rotors cracking around the drilled holes and said that their rotors are turnable by anyone who knows how to properly operate a brake lathe?
Who's BSing who?!?
And I'm sure they look great!
No BS! Do the research yourself and you'll find that guys who actually DO drive their cars hard have problems with cracking. And these aren't measily little A-Body guys, these are guys driving big-time cars, very hard. I won't ever run drilled rotors, ever! It's not worth the chance. Now, if all you do is daily drive your fancy rotors and look cool, odds are your rotors willbe fine. But, as the OP stated, he wants to drive hard.
not to be a dick, but maybe manufactures shouldn't put them on things like 80g Benzes or vettes or anything of that sort, god for bid putting them on a Enzo. Are you talking quality of the product or overall?
For what it is worth I rode sport bikes for years. Never raced them, just played on the streets. All of them had drilled rotors and they all still experienced brake fade. I contacted EBC and was told by them that fade is more of a compound issue than anything, at least as far as mst street type of situations. I also managed to warp every set of rotors on the front of every bike I had, and they were all drilled, slotted or both. Not saying that they don't help, just my experience with them.
Dont doubt what your saying a bit. One thing though, the cars these things are going on,3200lb A bodies, and the calipers they are equipped with,REALISTICALLY, are not capable of generating the heat or clamping force that would cause the cracking in the first place. Yeah I bet you are hearing and reading about high end stuff killing rotors especially when the cars in question have 13"+ in rotors and 4,6 and even sometimes 8 piston calipers and weigh between 3 and 4k lbs. Those things create HUGE amounts of heat and nothing but the absolute best available materials will do. OK back to reality if you guys are gonna get new rotors might as well get the 11.75" while you're at it.And I'm sure they look great!
