Anyone need a side job in Los Angeles CA?
My friends truck had 2 bad lobes, and it would pop out the intake and exhaust, shake, wouldnt rev over 3000, just horrible.
I have never had a cam lobe issue in alllllll of the vehicles I've gone through which is about 30.I guess I was about due lol
Well that no.6 cylinder had 65-70 psi and was the missing cylinder, though there was a clatter on the no.4 cylinder...it was the only loose rocker.
All the cam lobes looked great as well as the lifters, I pulled them out with needle nose pliers..however all the valves were adjusted too tight to begin with...so I reinstalled them, adjusted to spec, then began the cyl psi test
The rest of the cylinders pumped 105-110
Glad to help out, just save that cam for something else later cause that 273 is tired.
Great! Thanks For the help! You were a GREAT help with me being I'm 2000 miles away. I would like to see some pics of your valiants as well.
