ir3333
i am currently building a steel crank 371 as well
Doosterfy said:OK, I know its probably been discussed but I did a search and could not find the info. Anyway with that said I'd like to know if all 340 blocks are the same or if there's a particular casting number or year that's better or is there any years to avoid. I'm planning a small block build and I'm going to start looking for a good used and not used up 340 block. I don't need any info on cranks or any other parts, only the block.
Yes there are lots of talented shops down here, the trouble is its mainly Ford and Chevy builders. I'm not seeing a whole lot of Mopar action down here like back in the Northeast. I'll be willing to work with a shop that's within two hours driving distance and I'll only go to a shop that really knows Mopars well. I worked with a shop back in CT when I built my 440. Guy had been building race engines for decades and had a stellar reputation with tons of circle track racers. I should have followed my gut when I saw his reactions as soon as I said 440 Mopar. Turned into a long drawn out nightmare with my engine constantly getting put on the back burner and him telling me, "you don't need this, that or the other thing". What really blew my stack was when I got it home and discovered he had failed to deck the block like I requested and then the big argument with him. He told me I don't need to deck it, just use steel shim gaskets to bring the heads in tighter. I brought it back and insisted so he did the asshole move and took over a month to do it. As far as fuel, I will be using race gas. No alcohol, just gasoline.Wow! Indeed it does! I like what your doing. IF I could find a thick walled 340 for this project, that is what I would be looking for. Bigger bores have a direct impact of HP. Also, the bigger the bore the better the heads like it.
The bearing speed is a low issue for most purposes. You could also modify the bearing seat for a more narrow bearing shell. This is out lines in the MoPars engines book. A book with many secrets.
The 340 block is exactly the same as a 360 block except the bore size and crank journal size. While the crank journal is larger, it doesn't make it any weaker. As mentioned before, above, where are the stress loads?
If less metal is weaker, then here is a bit of food for thought. There's less metal around the piston in the block due to a larger 340 piston. But yet it holds up great! Torque is the killer of parts far more than horse power.
N.C. is a state with many talented engine builders. If you have doubts for any reason, here at FABO there are several talented engine builders who can help you out. Mike Listen @ MRL (screen name MRL) Brain Halflinger (spelling? Sorry Brian) screen name OU812, (Cracked back can tell you about him) are a pair of fellas here.
"Moper" does a lot of engine work as well. He is a sharp (and a goodfella.)
At 13-1, are you going to run E-85?
Not to crap on your builder because he is right to a degree and that would be a shorter stroke engine revs higher easier and the smaller bearings take less of a beating.my builder also says if your going to twist it to 8000 you should stick with the 340
I think you're going to struggle given the overall design you've envisioned. /QUOTE]
Agreed.
I tossed around the idea of building a shorter stroke combo myself but when you really start to look at hp/dollar spent, the stroker really becomes a no brainer. It's so much easier to make those numbers with more cubes. Why fight physics? Frankly, it looks the same from outside, no one will know it's stroked unless you tell 'em it is.
Just to discuss your point though - any 'real' serious performance small block Mopar head is gonna be $2,500-up when you start adding up all the pieces. SB Victor heads are coming out, what are they, like $3,200? Plus, (generally) the stuff that flows a lot of air usually involves offset rocker arms. Price those out lately?
600 hp is also pretty much solid roller cam territory. Roller lifters are not cheap plus all the headaches of retro fitting them in a block that was not designed for them.
Everything is doable of course, just depends how much you want to spend as the old adage goes. 13:1 is a lot of compression, maybe you could get there with that much squeeze?
Again, the block is not your limiting factor. It's your wallet.
I think its a viable package. Even if it failed to make 600 hp and say came in somewhere between 550 and 575, it would still be very fun to race. To be frank I've come to the conclusion that drag racing automatics is boring unless you can afford enough power where its difficult to even get it down the track. Ad a manual trans to make it more challenging and the fun factor goes way up.
Well I'd love to go road racing but lets face it, road racing is for rich guys and I'm not rich. I hardly consider drag racing boring either. In fact I've loved drag racing since I first saw it on TV in the late 60s. As far as the driveline I already have a rear axle that is more than up to it. Strange nine inch with a back brace. Its good for 750 hp with a manual trans or automatic with a trans brake. I know the transmission won't be cheap, believe me. I have ran a four speed car before so I'm not coming in blind. I'm considering an A-833 from Passon or I may look for a good used Jerico.Ha, drag racing is boring period compared to road racing/ trans am type racing. If you truly are going with a 4-speed drag car the block selection may be the least of your worries, you will need to bullit proof everything from the block back$$$. Also look into a 70-73 360 block for thick bore, only bore what is needed if you can get by with .010 or .020 great!
The car also has very good frame connectors that are notched into the rear frame and floors and are 100% welded in and a five point chrome moly roll bar. The suspension is completely rebuilt and there are Wilwwod discs on all four corners. Its well suited for a small block four speed setup.Ha, drag racing is boring period compared to road racing/ trans am type racing. If you truly are going with a 4-speed drag car the block selection may be the least of your worries, you will need to bullit proof everything from the block back$$$. Also look into a 70-73 360 block for thick bore, only bore what is needed if you can get by with .010 or .020 great!
Old man mopar, I have had early 340 blocks that can't take a .040 overbore. .
not an early block but a first run casting on a new mould before
core revisions,specifically 340 -1,and that could be any year.
i also heard 1970 blocks had the highest nickel content and were
the best blocks,but who knows for sure?
The last thing in the world I would do is spend lots of money on a combo then skimp on something as critical as the clutch.If you buy a junk clutch you will break parts. I realize this is an engine thread, but we are off track and I wanted to point out, once again, cheap, nonadjustable clutches break parts. No matter how good the parts are.
