Challenger
what trans can be used for overdrive automatic behind small block in dart ?
Curious, how is it not an OD? Final gear is .67 and that is the very definition of an OD.2..GM 200R4 or 2004R whatever they are---genuine 4 speed, not OD, but hard to find and a bit weak
Picky selection "in terms". What I meant is that it does not have "an over drive" (unit). It has an overdriven gear but it's not a separate overdrive unit. "It's not an over drive"Curious, how is it not an OD? Final gear is .67 and that is the very definition of an OD.
That would a an A518 based on the 727.727 out of a 89 dodge pickup truck, electric overdrive.
no floor cutting.
Yep splitting hairs there. Anything less than a 1:1 ratio is considered a O/D. (over driven) It really doesn't matter if the transmission has a old school design O/D unit bolted to the back or a modified tailshaft design, anything past the 1:1 is a overdrive. Simple semantics.Picky selection "in terms". What I meant is that it does not have "an over drive" (unit). It has an overdriven gear but it's not a separate overdrive unit. "It's not an over drive"
It's a built in gear not a separate OD unit. The Mopars have a separate OD component built into the big fat modified tail housing.. ...a completely stand alone physical unit. The mopar overDRIVEN 4 speed is also technically not an "over drive unit" because they took the 3rd gear slot and re-geared it to an overdriven gear. This is opposed to an "over drive transmission" like the older 3 speeds which had "stock" 3 speed guts with a separate OD unit in a modified tail housing
No but a 200 4R isUh, maybe a 700r4 is more slim?
Nice! Precision of New Hampton are good converters. Not too far away from me.The Stage 2, GM 2004R with from Extreme Automatics with a bolt on Reid Bellhousing is the best transmission I've ever driven. If you run a lock-up converter, it's the closest thing to an automatic 5 speed going. I run a Precision of New Hampton 3800 rpm stall, lock-up converter in mine with 4.30 rear end gears, slapper bars, 2 passenger side SS springs and Nitto Drag radials. The only cars that pull on me out of the hole, so far anyway, are the AWD Nissan GTR's. Those things scoot.
I did have to cut and modify the torsion bar cross member, but the floor remained untouched. They are limited to about 700 hp once properly built though, so I'm going to have to switch over to a 4L80 for my upcoming build.
Yes, that must have been the one I was thinking about.No but a 200 4R is
Yes, which does INDEED require floor cutting. I was wonderin about his statement, myself. Maybe he meant a 727 lockup?That would a an A518 based on the 727.
...And when built is stronger than any 700 could ever be.No but a 200 4R is
Why not go with the Extreme automatics Stage III 200-4R? It's supposedly good for 1000hp/750ft-lbs torque. I know it isn't cheap but it's an easier swap than the 4L80 from what I understand.I did have to cut and modify the torsion bar cross member, but the floor remained untouched. They are limited to about 700 hp once properly built though, so I'm going to have to switch over to a 4L80 for my upcoming build.
