Way faster too![]()
Yeppers
Way faster too![]()
True Dat. I finally got some QA-1 Upper C/A's and tossed the offset bushing/stock setup. Muuuucccchhh better now! I have not driven the car hardly while other projects were underway. It helped to find an old school auto shop to do the alignment correctly! BTW the airdam is still like new and does enhance to overall front end appearance and gives a "muscle" seriousness to the car.Marion, your car needs a front wheel alignment real bad!
I ordered one up fro the '74 Duster. 10 minute install this weekend. I went ahead a put a self-tapper in the bottom of the fender to keep it wrapping around the outside. I really like the look.
--------------LIKE ! Would need the outside corners rounded to look right on a 68 fish , to me .That nice, but it will only fit on a few A bodies that are built like the early A with the lower valence.
It would appear that you being led all kinds of ways. I believe the first comment was for a Spoiler by Randy. Ordered one from him for my 75 Swinger primarily for cooling purposes. It fit perfect. Again get what works for you.
The spoiler works. I am running a Magnum (5.9) now 408 with a factory type replacement 26" 2 row rad, and a 180 stat. Has an under drive water pump pully and a 3.91 sure grip. When on the I 35 @ 75mph and stays at 180 with the A/C on.
old post----------I had the GTS out today and I can say that the spoiler is solid as a rock up to 70 mph. I also believe I can feel a difference in the car with it on...in a good way.
getto ?????? spell check please... no life lines! lmfaowhat a dumb ***..
I used some of their ceramic wax stuff on mine to make it a little more glossy, also much easier to clean.
I put one on my fiberglass tilt front on my racecar. The one I bought I had to take either 4 inches out of it. It's exactly 3" off the ground
