My clutch pedal setup is not that great looking, and mine was not a manual car to begin with. I wanted to install a stock clutch pedal setup but everybody at the time wanted an arm and a leg for it soo I just went to the junk yard and found a clutch pedal out of a vw golf mark 3 and made it work. Its obviously not professional but worked out for me and after 2 years its still holding up even after a lot of abuse! There are several other members that used the stock clutch style setup with better results, I just went my way because I was on a budget but hear are the pics of it.
Bad thing tho the E brake is removed which I have no E brake which im gonna set that up pretty soon! Just giving you an idea on my setup but I would LIke to see some pics of kenneygene's setup!
Now that's HOT RODDIN'!!!! How did you connect the speedo gear? Stock pinion?
Greg
