It's my fault:snakeman: I bought a pair of SV1's instead of King Demons:munky2:
That's obscene. lol
i can get a hole blow system for less than that lol:sign10::tongue9:
whats Don at FBO going to sell now ?
Earlier in their life, they had issues with new carbs that would mysteriously start to show metal in float bowls. The cause (From Barry himself) was drilling aluminum. They would drill a certain passage, and the aluminum bits would be compressed at the bottom of the passage by the drill. After the carbs were run, and vibrations from the engine and the road, they would vibrate loose. Barry and crew figured out the problem, and would run a smaller bit down the same passage afterwards to break up any compressed shavings loose so the passage was clean.I keep hearing that , whats the story with the **** in the float bowls.
Do we chalk it all up to an economic down turn? Or what?
Small Block
Economics, and mail order.
Face it, there are less carbed vehicles on the road every day. Much of the aftermarket carb business is done via mail order, and for a supplier, Summit and Jegs are not the easiest people to do business with.
Good 1 stroker!!! and now it will be Scott Walkers fault.........It's all Bush's fault. Somehow.
They also earned a bad rep with a lot of racers. When I researched fuel systems and carbs for my project I found warning after warning about BGs lack of quality and worst of all, poor customer service. It's one thing to occasionally let a bad product out the door. It's another thing to treat the customer like crap before you make things right.
Thanks Ed,under 1200 cfm,,,,,,,,,,,,,,,,,,,,,,,,,,each:wave::toothy5::hello2:Those are made here in the USA:usa2::snakeman:Those things are rediculous! LMAO:notworth:
I always liked Holley anyway.
you are smart man......Artie(.o and will I'm on here do you remember the wild bunch out law racers form back in the 80s)It's my fault:snakeman: I bought a pair of SV1's instead of King Demons:munky2:
Man that stimulus is working like a champ!
