That's the way I just wired mine. 4 post switch. I ran a 8 gauge wire from the small post to my msd box. Flip the switch and it kills the power from the battery, and the power to the ignition. When off, there is no power in the car. No relays needed.
Have you put a voltmeter on the alternator charge post?
That line is hot if you hooked it to the battery.
I know this has nothing to do with the wiring, but since this thread popped back up and I think it's a cool idea, I thought I would share it here.
One of the guys on the B body forum runs a kill switch that is a push/pull switch. Rather than come through a metal panel on the car, he came through a tail light assembly. Now if he ever converts the car back to a street car, all he does is get another tail light lens. Just always thought that was a cool out of the box idea.
Can someone post a diagram of a 2 post battery cutoff switch with a 3 wire alternator and a start button . This the first time for me wiring my race car from scrach . I have a painless 8 circuit race kit and have not started yet . Can someone lead me in the right direction for good instructions on wiring Mopar Charging and Starting system is what I need help with
Thanks
Thanks
Doug, I don't believe that is true if you use a 4 post (DPST) switch and a three wire alternator. The entire reason for doing so is to avoid a separate (hot) alternator line back to the battery
A "one wire" setup might be a different matter.
But your post brings up one of my favorite "fake" testing procedures, that is, do NOT ever remove a battery connection on a running engine.
Here's one easy way to do it:
Buy one more good heavy relay or "continuous duty solenoid." These have two coil terminals, not grounded to the case. Run one small terminal to "ignition run." Run the other to the rear with no14 or 12, wire it to ground through the small terminals of the disconnect.
Hook one big stud of the continuous duty sol to the batt. term. of the starter relay, hook the other either to alternator field or the ignition system/ regulator feed. I did not show a fuse or breaker in that circuit, a good idea. If you feed the output of the solenoid to the "blue" ignition run, it will control BOTH ignition power and alternator field on 70/ later isolated field units, as well as the "input" of the regulator.
Run your starter cable to either the starter, the relay, or a big junction stud and interconnect as shown.
