Bench seat location
olddog12
Nova Scotia Ehh
I've got a '74 Scamp and trying to figure out where to drill holes in the floor to install to OE bench seat. The PO replace the floor and I dont know where the holes would have been. Im not concerned from side to side as I can just center it. Can anyone perhaps take a measurement for me? I think from the rear would be easiest to measure as it is flat where the rear seat sits up on the "ledge" or raised part.
Thanks guys.
A factory floor would have "dimples" where the holes would be drilled. I assume your floor doesn't? The bench rails run on those raised ramps -- the front bolt is an inch or two from the front of the ramp. Under the floor, there should be a C-channel reinforcement plate where the holes would be.
The floor was replaced with doner panels from another dart but 3x3 frame connectors and 2x2 brackets from the rockers inward about 20 inches were installed and the floor was installed around & welded to them.
Think I have it figured out now tho. Thanks!
