A904
For standard-duty applications in smaller and lighter vehicles with 6-cylinder or small V8 engines, the compact A904 (later 30RH) was introduced in 1960. This transmission used a 10.75 in (27.3 cm) torque converter. There was also a smaller version of this transmission used in the Dodge Colt/Plymouth Champ cars made by Mitsubishi in Japan. This smaller transmission used a 10 in (25 cm) torque converter.
Uses:
1960-1976 170 , 198 , 225 Slant Six
1964-1969 273 LA-V8
1967-1978 318 LA-V8
1975-1978 360 2Bbl LA-V8
1972-c.1978 AMC I-6 "Torque-Command 6"
A998
The A998 (later, 31RH) was a medium-duty, wide-ratio version of the small-frame A904 transmission for use with medium-power V8 engines and the 3.9 L V6 engine.
The 998 was equipped with four direct friction plates.
These automatics had lower first and second gear ratios to allow the lower-powered engines to provide better acceleration without sacrificing highway fuel economy.
A999
The A999 (later 32RH) was a heavier-duty, wide-ratio version of the small-frame A904 transmission for use with medium-power V8 engines and the 3.9 L V6 engine.
The 999 was equipped with four or five direct friction plates.
