Best ET
A360 said:
Update
12.84 @ 108.3mph 1.9 60'
1970 VG Valiant Hardtop (Dart)
Mild 360,727,3.7 gears
Cheers
Benton
Nice times, id think you have a couple tenths in the 60ft you should be able to pick up. My 14.0 318 60's at 1.9. :thumbup:
8.41 in a buddies front engine dragster. Personal car is 9.30 @ 150 mph in my chevelle, best Mopar time is 9.40 @ 147 in my Charger .
11.29@116mph...'70 416 stroker duster,going for tens in a couple of weeks... :-D :-D
My best et was so long ago. 73 4 speed 340 Callenger with a/c and 3/23 gears.
Daily driver Bone stock and left a 71 chevelle in my J stock class two cars by half track and ran a 9.02. Can you say, Deep stage 00. Ok I got a good light.
The chebby guys had to lift my hood and look for headers that was not there.
102 octane at around 41 degree's sure makes a difference! back in the day!
Jerry Mirer's took me for a pass as a passenger in a 6.50 1/8 mile car a 69 440 barracuda.
What a ride. :burnout:
1/8 mile to the cooler in flip flops was 58.07 sec. :drinkers:
Updated
12.7 @ 109.3mph
Good update mate. 12.7 man that would be getting it dun. :thumbup:
mikedevore said:
1973 Dart Sport, std. bore zero deck loose short block, unknown cam - mild, out of the box eldo heads, holley strip dominater intake, 750 cfm holley double pumper, 1 5/8 headers - full 2 1/4 exhaust w/dynomax turbos, 10 inch coan convertor, low gear 904, 3.91 suregrip. Driven to the track, best numbers so far, 12.80 @ 105mph thru the exhaust on M/T drag radials. 60 foot times in 1.70's. Going to the Mopar show this weekend, hope to go faster! I can't wait to get a freash short block in the car this winter. Maybe mid 12's next summer.
I have a freash short block, changed cams to a Hughes 5256AS solid, changed headers to 1 3/4 Hookers, changed convertors to a Dynamic 9 1/2, best ET so far is 11.84 @ 111 MPH!
New best..11.06 @120 i'll get that 10 second slip yet..
12.95 at 104. 1.84 60'.
360, "J" heads, stock valves, 904, 8 1/4 with 4.10's,
Mp converter, 480/230 cam in my 3480lb 75 Dart.
My best ET this far 12,11 113mph with 408 stroker original ported heads edelbrock air-gap manifold and holley 750 carburator
I was out on the race track this wekeend and finally got my 11 second run.
I run 11,93 114 mph
Forgot all about this thread. Took the Duster to the track back
in april. Got about 4 passes. The best was a 12.93 at 105.
Went up for the 5th pass and broke the front U joint and slip
yoke. Haven't been back at all this year. Put the old trans back
in to go through the good one. Still have to check the overrun
clutch. Hope I didn't hurt it. At least I finally got my 12 sec.
pass. Hope to go faster next year.
10.66 @ 120 hitting rev limiter approx. 200ft from traps(too much gear and not enough tire), 1.55 60 ft. 71 Demon 493CI MP SS springs w/CE shocks. Saving $$$ for correct gear/tire combo. Hope I can get it in sub 10's. LIVE TO DRAG!!!
11.66 @ 114.65 the first time out at the 1/4 mile track. Looking for more as I will be going back to the track real soon. Ron
