Barracuda_v8
I need a new Water pump!! which one should i buy???
I believe the HP ones are 6 blades, that way you get the 6 blade without the price of MOPAR which is like 60 or something. This is what I have on mine and reuse it everytime the motor comes apart.
I have the 6 blade HP pump! doesn´t work on my stroker!
Am I the only one that still runs to NAPA for things like this?
"I need a water pump for a 68, 340."
For a Stock type engine for sure I would go to NAPA.
I have always used pumps that were designed for AC equpiied cars. They have more blades and move the water faster. As far as the best brands I have no idea if one is better than the other.
my stroker is running a 6 blade...
Performance quotient engineered pumps will flow 35 gallons per minute at 4,000 RPM, with minimal cavitations and proportionally increased flow rates at 5,000 RPM and above. Equalized water flow distribution and pressure-balanced water passages minimize internal engine hot-spots making these pumps an excellent alternative for not only racers, but also trucks, towing, and motorhome applications. Cruisers and hot rudders will appreciate the improved cooling at low speeds and the polished aluminum water pump bodies. Block-to-hub 5.550 inch.
PRW 1431800 Feature Review
Steel hubs and heavy duty shielded-seal roller ball bearings
Pressure injected aluminum alloy pump bodies
Back plate "O" ring sealed for competition plus applications
Reliable cast iron CNC machined impellers
Satin-cast
Yeah, I don't know how much the Water pump has to do with the cooling I would think the Radiator/Fans would be doing the majority of the work.
With the Raised Dam walls on the PRW unit I am thinking that cavatation at higher RPM's would be alot better.
Here is their sales pitch....
Here are some better pictures of the Dam walls, Impeller etc.
A majority of the work? IDK but my system cools so well, sometimes I dont even have to run the car with the fans on. But to all his own.
This is for informational purposes only. Take it as you wish.
What is your initial timing at? What is it at all in? I am curious.
34initial, locked out
What kind of Radiator?
Is this the same motor you have pulled apart several different times?
Is it still running or is it down now?
Champion.
nope 410 stroker and car is apart to be painted
