Hi I've searched online everywhere for some billet adapters to go from SBP to LBP No luck anywhere? Anybody know a supplier for this size? Thanks (frustrated)
His list says it does not fit disc brakes on later model (post '72) A bodies- which makes sense since those are already 4.5" bolt circle; drum brakes in those years were still 4".The ebay seller said does not work with disc brakes? have you heard that before? Anybody?
If you need 4, order 2 sets. Or look at other vendors that sell in sets of 4. Lots of them out there, these weren't the only ones. Just used them as an example.
Yeah, agreed. His "fit" list kinda skirts around that.That’s a silly way to say that if that’s what it is. They fit 5x4”, not fitting the 73+ disks has nothing to do with the fact that they’re disks. Just the wrong bolt pattern.
You won't if you get some wheels with 1" more backspacing than what would normally fit on the car. You need somewhere around 5" BS on a 7" wheel, for example. You are looking at, for the most part, front wheel drive designs like the white ones shown above.Those look good. I hope you don't have wheel well lip rubbing problems on the front.
