Biohazard
Thanks, man! I'm happy with the outcome. Sure, it's not what it could be properly chromed and all that but where my purpose was to merely clean it up and NOT spend the $400+ for the repro...I call it a win.
And as I was looking at it in the corner, I do believe I'm gonna like the solid black centers.
Tomorrow I should be sifting thru my hardware, getting the big parts bolted together, putting the wires in position and taping up the harness. I'd like to be hauling it home like that.
I would call it a win as well!!
The centers on a 69 should be black with a white highlight around the circumference .
Hey Rocker - thanks! Yeah, you can spruce up your dash if you know, going into it, what the limitations are for the DIY'er (such as chrome-in-a-can isn't all that chromey) and that your expectations are appropriate. I was wanting mine to be presentable and not all splotchy or flaky. But yeah, time & patience > $450. If I go to a nicer cluster, it will only be after I have the car running 100%.
Tidying up some loose bits. A crack in the plastic that I repaired with JB weld has failed and is a crack, once again. Dremel'd out the old weld, creating a channel, and filled it with fresh JB and a straight section of heavy paper clip wire for reinforcement. JB bonds to metals much better than plastics.
Managed to pop one of my gauge faces off it's brace so I glued it back down with a dab of JB as well.
Identified which screws go where so I'll be ready to reassemble once the bonds are set up.
Haven't done much else today as I actually had to work solid up till 2:30. Just need some peace for the rest of the day.
Now to go clean my helo's windshields. :D
I was like, "huh?" That's just a decal. But there is a G-Dec under the bed cover \\:D/
Kicking off Sunday with a little retro fish-****. So there I was with this battered, unloved '69 and an olive green interior which I was also not loving. In the gravel parking lot in front of my awesome, stick-frame, built-in-the-50's Army barracks I pulled out the interior and did a shade-tree color change.
Metal and plastic parts got primed and painted. I used spray cans of vinyl dye for the door panels and visors. My barracks room (seen below) served as my drying booth as it was a tad chilly in the Tacoma area for such things. Tip-toeing around this stuff for two days was no fun at all.
This was 26 years ago. Wow.
With the primary dash pieces in place, I can lay out and wrap the wiring harness.
Got everything fairly well sorted. Spent a significant amount of time actually wiping each individual strand of wire with a rag soaked in ammonia. Commitment, people.
Cleaning oxidation off the primary power connections. Things like this can really make a difference.
get some stainless steel screen. i usually cut a piece to fit on the hidden side of a crack/break/whatever and use a wood burner to embed within the plastic.
works better than most of the goop they sell in tubes
Try to imagine how much you would have to pay some one to do all that. Now multiply by 10 and that's your satisfaction factor! Keep it rollin!
I can imagine that. I'll just think, "what would I charge for all this?" lolz
And yes...anytime you're using any sort of epoxy - results are much better when there is a reinforcing medium infused.
Summary for the week (because we had such a light week, I got all my work done already)
---While I wanted to go home with a singular, completed assembly, there was one piece I forgot to bring that is keeping me from screwing all the big parts together. That long metal strip that goes across the top of the plastic cluster. No big deal. All of the pain is over and reaching the stated goal is only about 10 minutes away - turning a few screws and tightening down the various switches on the panel.
**actually, I have some felt sound dampener to glue to the inside of the frame but that won't take long.
Yeah, it always seems that way when you complete a 'phase' but then you actually get back to the vehicle and it becomes clear that there's still about 25 miles left to go in this marathon.
On a positive note...
Busy morning here in the office. Finally got some time to glue down a little red felt (noise suppression) on the back of the dash frame. Now it is official: I've worked myself out of work for this shift. Now I let the glue dry and pack everything up in the truck bed for the ride home tomorrow evening.
Managed to find something more - decided I need this so I just ordered it. Too much work done on the harness to skip getting a nicer one of these.
One thing a day baby......
So true! And today, it's new Centric drums! Not identical to what came off the car but a quick scan of the internet suggests that what came off the car aren't really all that correct. Might also explain why the old brake shoes were a tad narrower than my replacements.
Don't know if you've considered this but installing a dedicated ground wire to the back of the instrument cluster, bonding it via ring terminals to each circuit boards ground screws and then running it back to the chassis or even to the battery negative will give you a low impedance ground path and your will have no issues with any gauges. Keep up the good work.
Very good idea.:prayer:
Here's just one of the rear slave cylinders broken down and emptied out. The plastic cup is pure white.
And here's a look down the bore of the slave.
