PlumCrazyChris
Yes I have a modiction
Right on, I'll give you a shout.Are you back in Austin?
If so give me a call, I am here most times during the day, Playing blues at night. You can come see the progress, punch the buttons and have a beer
whats the "fire" relay for?I decided to set up a rainy day project for the weekend, hasn't started raining yet, project done.
There are a half a dozen major control centers (relay modules) in the Missile. The one for the front grill and hood subsystems has been wonky for a while. It was the only one I actually soldered relays directly into circuits without relay sockets. Guess where the problem was.
So I made a new board with relay sockets and then transferred all the wiring to the new board, installed the relays, and plugged it back into the car.
All problems have been solved.
Electrically triggered fire suppression system.whats the "fire" relay for?
nice! where'd you pick that up at?Electrically triggered fire suppression system.
(H) SPA AFFF Fire Suppression System - Pegasus Auto Racing Suppliesnice! where'd you pick that up at?
THanks!I'm always impressed with your work Andrew.
Let me say that the actual system is wired directly from the battery to the avionics pod on the console. That switch triggers the relay as well. The relay shuts down the fuel pump and the ignition system and oil system solenoids.whats the "fire" relay for?
NICE! so one emergency button triggers all that?Let me say that the actual system is wired directly from the battery to the avionics pod on the console. That switch triggers the relay as well. The relay shuts down the fuel pump and the ignition system and oil system solenoids.
nice! whenever i get to that point, I'll be beggin you for help wiring my stuff up, I hate wiring lol
I figured it was for the -----BLUE MISSLE !whats the "fire" relay for?
Yes I am still here. ....................
More later, have patience, TRUST THE PLAN!
Yes I am still here. Yes I still have the Missile. Yes it is still in maintenance mode. Yes my son graduated college this past summer. Yes I am still waiting for certain investments to grow enough to fund the balance of the build. 472 smallblock aprox 35K-40K, the tranny is 9K paint job 3K PM me if you want to send me a check.
In the mean time I build guitars and play the blues here in Austin. I have completed all the small projects (sub systems) I set aside for a rainy day.
Wait!!!! I still have to vacuum bag some carbon on the A pillar trim, that will happen fairly soon. I gave up on trying to find re-pops.
Any time, call first leave a message, you will be speaking to Liam Neeson.Hey Andrew, still want to stop by and see your progress. Its going slow on my Duster. got the engine all hooked up, but need to try and fire it off.
Hope your doing well.
Chris
Not yet, but it will be soon.Did this car ever get finished ?
