VolksDuster
Back Yard Guy
Hi There, Im new to the fourm under this name and it has been a long time since I have been on here. But I have a Twister again and will for good now, I think.
This is a 1973 Plymouth Duster/Twister with a 318 and Automatic trans, I have an issue where the car will start and idle fine but under load (in any gear) the car boggs and dies as soon as I hit the pedal. At this point I thought it would be either dirty carb or bad vacume advance, so I cleaned the carb and replaced the vacume advance. No Change in symptome
At this point I decided to replace the carb and distributer as well as Coil, cap, wires, fuel filter and breather, Also I decided to replace the chain and gears because the was a little slack.
And this is where I am now... All parts replaced and adjusted, and the car is still to be doing the same thing, I`ve tried advancing timming, retarding the timming, adjusting the accelerator pump, adjusting the idle mixture. Also checked for vacume leaks (none) and nothing seems to change the bog.
So I`m hoping some can tell me something so I can drive the car for a while before the snow gets here.
Thank you very much
Thank you very much
