I've watched SS 396 Chevelles run a 16 flat in the qtr., same as My "Killer6"......I've had a few v8s that couldn't get out of their own way before.....
That would be some hurt feelins to get outrun by a slant 6 in a big block Chevelle. lolI've watched SS 396 Chevelles run a 16 flat in the qtr., same as My "Killer6"......
My buddy had a '75(?) NOVA 4bbl/4spd/350, won the Street-class bracket championship that year at Keystone, beat Him 3 out of 3 on Hunter stretch one nite, getting that car moving on a cool country road at night ain't the same as a clean & prepped track....lololol!!That would be some hurt feelins to get outrun by a slant 6 in a big block Chevelle. lol
Man those things got really FUGLY from 73 up. lolView attachment 1716153614
That one....
That boost level is gonna take E85/Water-Meth inj./Intercooler, one of those 3, 7-8psi is pushing it w/o any of those. There's a big difference in 300 & 350hp, boost can get You there sure enough, but the piston that lives @7psi may not @12psi for sure. You can look at what the PowerNation mill did, but it ain't a cheapo build, so what are You in for$$$$?I was under the assumption that all 2bbl slant intakes were super six??. Either way shooting for 3-350hp at around 10-12psi. More is always better though!
I wouldn't think those boost levels would be pushing it for a slant with stock compression. They normally blueprint down in the 7s. Perfect for forced induction.That boost level is gonna take E85/Water-Meth inj./Intercooler, one of those 3, 7-8psi is pushing it w/o any of those. There's a big difference in 300 & 350hp, boost can get You there sure enough, but the piston that lives @7psi may not @12psi for sure. You can look at what the PowerNation mill did, but it ain't a cheapo build, so what are You in for$$$$?
Yeah, I'd never use the factory 2pc. Super6 intake, iron or DC/MP cast Al-U-minimum only. Welding bungs in an iron intake isn't needed, they can be brazed in, or drilled & tapped for threaded bungs....OP is planning on Sniper(TBI), so moot at the moment..Many of the aluminum slant six manifolds had leakage issues, although if it doesn't leak under vacuum, it won't leak under boost.
Cast iron super six manifolds will not have leakage issues, but welding port injector bungs if you go EFI would be a challenge. I also would be concerned with a TBI about fuel distribution issues, although it may work. It may also be possible to prep a BBD (or two barrel Holley, probably more info about those) for blow through use.
Why? Most of the defective ones have been out of the system for a long time. There was a TSB on them I believe and most got replaced. I have one that had I pressure tested that's excellent. I like them. They are light as a feather.Yeah, I'd never use the factory 2pc. Super6 intake......
A few years ago I went to a "street legal" night at Gainesville Raceway. First run was heads up against a 61 full size Chevy with a 350 and B&M blower (beautiful car). My car was a 66 Barracuda, with a 170 slant six. I had him at the 1/8 mile, and he got me by about a 1/2 fender at the 1/4. He couldn't believe all I had was a 170 slant six (on spray). Went a 12.905 at 101.85 mph. At 3250 lbs and thru mufflers.That would be some hurt feelins to get outrun by a slant 6 in a big block Chevelle. lol
Because I can't tell the difference between one that was replaced under warranty and one that wasn't just by looking at it, and having worked at a few dealerships, many folks don't get their car serviced there & ignore snail-mail, e-mail, & even messages on the freakin' dashboard that there is a recall/campaign that is safety related.Why? Most of the defective ones have been out of the system for a long time. There was a TSB on them I believe and most got replaced. I have one that had I pressure tested that's excellent. I like them. They are light as a feather.
Now that's a cool story!A few years ago I went to a "street legal" night at Gainesville Raceway. First run was heads up against a 61 full size Chevy with a 350 and B&M blower (beautiful car). My car was a 66 Barracuda, with a 170 slant six. I had him at the 1/8 mile, and he got me by about a 1/2 fender at the 1/4. He couldn't believe all I had was a 170 slant six (on spray). Went a 12.905 at 101.85 mph. At 3250 lbs and thru mufflers.
Excellent post.Not all 2V Slants were necessarily branded as Super Sixes, but they're virtually identical other than the manifold material. My '78 ex-USAF D200 4-door had a cast-iron 2V manifold but no "Super" designation on it. Everything interchanged with Super Six Volare parts, so to me it was a Super Six. There wasn't much super about it in a 6,500lb truck, though.
The limiting factor won't be the intake manifold, it'll be the cylinder head, especially on a Slant larger than a 170. Oversized valves and porting are time and money well spent, particularly with forced induction. Intake manifold (boost) pressure is a measure of the resistance to airflow. In other words, the PSI reading is simply telling you how much air is not moving through the engine. You'll flow more with a ported/valved head and 12PSI than you will with 15PSI and a 100% stock casting. More air through the engine = more fuel burned = more power. It's no different than natural aspiration, really, except now there's pressure at the valve when it opens rather than a vacuum being generated by piston movement.
Similarly, on the exhaust side, the factory manifold will not be the major restriction--it'll be the turbo. The lower the backpressure after the turbo--the exhaust system--the greater the pressure differential across the turbine wheel. Less pressure after the turbine = quicker spool times/less lag. There is no such thing as "good" exhaust backpressure with a turbocharger.
Just like water, electricity, and human nature, any resistance is exacerbated by increased pressure. This is true on both the intake and exhaust sides.
"Street Turbocharging" by Mark Warner is an excellent resource on this subject. It might not be as entertaining as reading internet forums, but the advice is consistent and solid instead of conflicting opinions. It's well worth the price and a couple of full read-throughs to fully digest it. There's a heck of a lot more to forced induction than just hangin' a turbo on the engine and calling it a day (especially regarding ignition timing). Learning the hard way is a lot more expensive than a book and a few nights' worth of reading.
