DusterBoy15
THE WISE(guy) MEMBER
when i build my motor i want to run pump gas and the max is 91 im in CA so go figure. So i want to know what the max i can bore the motor to increase the C.I and would using a 340 crank help thanks
very true.....GoodysGotaCuda said:360 crank would need the main bearing journals milled down, and special pistons if i remember right. adding more than a couple cubies usually isnt cheap. So depending on your budget...
toolmanmike said:I read the responses twice and everybody forgot Duster Boy's original question.
DusterBoy15 said:when i build my motor i want to run pump gas and the max is 91 im in CA so go figure. So i want to know what the max i can bore the motor to increase the C.I and would using a 340 crank help thanks
Stock engines came with the thinest head gasket.toolmanmike said:You can also install thinner head gaskets for a slight increase.
toolmanmike said:Boring the block doesn't actually raise compression and neither does a different crankshaft. Those two options just force you to install different pistons with the ratio you want.
