DusterBoy15
THE WISE(guy) MEMBER
so 9.0 pistons .030 over sound good?
what about knifeing the crank?
i do belive that this correct. 1991 is the last year for the 302 cast. the ones i have are 1988. i think the magnum heads took over after 1991....ValiantMike said:Heres 302 head info.
4323302 1985-1987 318 2bbl swirlport 1.78" 1.50" 56cc - 65cc
I was also told that they were on 318s up until 1991 but I can't verify that info. Mike
rumblefish360 said:I was thinking of a fella I just got off the phone with that has used a 360 crank with 318 pistons.
BJR, stage is yours.
moper said:Dusterboy, What background do you have in engines? The reason I ask is there is much more than ordering new pistons or turning a crank and just sticking it together. That is a recipe for spending money many more times than you have to. I'm assuming you dont have the unlimited budget. What do you want out of your car? How much money do you honestly have to play with? What have you already done to the car?
In order to swap strokes, you also need to replace pistons and rebalance the assembly. In order to replace pistons, you need to rebore the block, and re-hone, and rebalance. You will also need new rod and main bearings, and now ring, plus cam bearings and block hardware, plus completely disasemble the engine. Basically, a rebuild. The compression is a big part of power, but you cna make power in other ways without spending on a rebuild. SO what do you really want to do?
DusterBoy15 said:i got the books thats why im asking but i dident see a part saying anyhting bout needing different parts i was jw so are you saying that i cna bolt them right on and bot a regular intake and headers on or what?
and if i get 9.1 compression pistons what will the compression be with these heads
LOL, OK then. (It's brain twisting sometimes after the midnight tour.)o sorry jw means jsut wondering and or what means like if not what not what im saying then when what do you me
