Brake drum removal HELP
That one is the half inch size as noted by the thread @Daves69 posted above.
Nails cut, bottom of drum will pull out.
top of drum will not give.
Have you tried disconnecting the brake line and unscrewing the wheel cylinder??? That's most likely what is holding the top up, the nail studs from the wheel cylinder to the brake shoes...
Cutting the pins Gained you nothing, it still won’t come off.
You still have 3 stumbling blocks as noted in the photo. Top anchor, and both wheels cylinder struts.
Now how do you overcome them?
Yeah, that top triangle washer with the springs for the shoes may cause a problem...
But with the bottom looser and the wheel cylinder loose, he may be able to heat up the adjuster better...
Wafer wheel on an angle grinder.
Cut a groove across it.
Cut where you won't damage anything inside.
Cut a notch for a wedge.
Big hammer...... Bam bam bam.
We cut rusty cast conduit fittings all the time when a big pipe wrench doesn't work. The crack will follow the groove you cut.
You cannot unbolt the backing plate from the car without the drum off, there are 4 nuts and bolts holding it on and you need to access both sides.
And why the big desire to cut the Swedges? That’s not going to gain you anything. The drum is stuck to the shoes, the bearings look greasy and not rusted so they will come off when the drum is free.
The other side has had it done. It's not a bad idea because you don't have to remove the spindle nut and deal with "all that" if the drum will simply slide off. It's no big deal, because the drum is hub centric, not bolt pattern centric. The only ONE reason they swedged them on from the factory was to keep them from falling off going down the assembly line. Replacement drums have the holes so big, you couldn't swedge them if you wanted to.
By either working the adjuster loose, or cutting the drum off. I agree with you. Cutting the pins really does nothing. Well......maybe gain him a couple of inches...and not where it counts.
I don't know if this applies to your situation but have you opened up the bleeder valve to relieve any pressure that might be built up? I say this because I just had a drum that was frozen on my right front on account of the brake cylinder being full of rust inside and acting like a one way valve. When I stepped on the brakes it pushed the shoes out but the pressure would not release unless I opened the valve. The drum was totally locked up. When I opened the valve the drum came right off.
Ok, wow. Lots of comments really fast.
Here is how it worked out.
As 413 stated the stumbling blocks of the process up until now.
By cutting the nails I was then able to pry the bottom of the drum open enough to see the entire inside. I blasted all of it several times. Then heated the adjuster, then blasted it, then heated it, then blasted it. Nothing.
I got out the sawzal and cut the adjuster into two pieces. Didn't damage the drum since I could pry it apart after cutting the nails.
The second the adjuster was not in play the drum just fell off.
However with the adjuster on the upper cylinder was definitely the problem. This would have never released.
This is the car I was working on today.
Thank you guys very much. Every single comment helped me get this drum removed. I'm very surprised how long it took. Hats off to every mechanic out there as I am impressed every time I complete a single small project.
Well great! You got it off without a lot of carnage. That's always a good thing! Nice work!
Glad it’s done, feels good huh? Came right off with the swedge intact, It didn’t mean a thing as far as the binding problem.
Hope all readers learned something. I’ve done this task far to many times. Oxy-acetylene torch is my favorite tool!
I bought it with intentions to cut it up for metal pieces for my true town driver. After getting it in the garage I realize that there is zero rust on the entire body. No holes. No bad rails.
I can't bring myself to cut the car up.
Figure I'm gonna stash it or sale it. Buy amd metal or piece's of other already cut up cars.
I sure appreciate learning what the swedge is and why it was used.
Truely thankful. I'm glad to have a thread that hopefully someone will be able to read all the steps to get these drums off when problems arise.
If you can get a decent pry bar between adjuster and shoes, it should pop off.
From all the replies i can see lots of us have dealt with this a time or two. And different methods have worked.
Flying drop kick and a sledge hammer. Cutting drum sucks, but i have had to do it. Front spindle complicates it.
Glad to see you didnt let it win.
And not wanting to cut car up for parts, i can respect that. They dont make em any more,should mean something.
I'm really glad he salvaged the drum. They are getting harder to find every day.
Next time I would pop the upper and lower ball joints , remove entire assembly and either buy a used assembly or soak the existing one in a deisel/acetone solution for a week .
