Brake push rod
cmac64dart
mays landing nj
Just curious what you guys are doing to convert your early brake push rod to a modern master cylinder. The early A master cylinder had threads. My new master have them. Am I missing something. Im doing a Drum disk conversion.
I just converted my '66 the same way....from single master drum to dual master disc. Bolted right up and the push rod length was correct too. I don't know what your problem could be. Maybe a photo of your parts? What threads are you referring to?
The stop plate on the push rod has screws that bolted to the old master cylinder. The new master cylinder does not have these threads
…because the dual master cylinder, if you select the correct one, has a snap ring for the piston stop. No external bolt-on plate needed. The master cylinder you want is linked here, along with other suggestions for a successful drum-disc swap. Also see here.
You'll need a distribution (splitter) block; this can be had used from any A-body with 4-wheel drums, '67-up, but those aren't exactly common in the yards any more, so probably easiest to get it new from Inline Tube. You'll need to run dual hardlines from the new master to the splitter block. Be sure to bend two fully-circular loops in each of them to let them flex. Steel line is standard and is a pain to work with; Cunifer is a lot easier (and better).[/B]
Ok so I do have the snap ring. How do you remove the rod from the old piston? I gave it a few light pulls but I don't want to force anything. Pictures appear that it just pushes into the new piston.
Ordinarily I'd say Step-by-step is here, but it looks like you've, ah, already done quite a bit of disassembly. You're doing to have to resort to more violent methods (or do some quick-and-sloppy reassembly and work forward from there according to the link).
You may need to re-use the rubber retainer bushing, so mete out your violence on the pushrod with care.
Dan,
As usual thank for your expert advice, so I am building a 63 Dart Wagon, Staying with the small 9x2 shoes in the rear, Does this MC still serve correctly? https://www.amazon.com/dp/b000c71k0u?tag=namespacebran131-20
And this distro block? https://www.inlinetube.com/products/blk243
Thanks in advance.
Lucky you salvaged the rubber bushing which locks the brake rod in the MC piston. I did a test fit with a new bushing once, then had to remove the rod (to slip on the dust boot) and tore up the new bushing getting it out. I bought them from a brake vendor (Dr Diff?). My 1964 Valiant is manual drum brakes, but I changed to a dual MC, using an aluminum 2-bolt one for a 1999 Breeze ABS ($25 new) with a 2-4 adapter plate ($30 ebay). The brake rod fit and the pedal wound up in the same place. I glued a dust boot to the MC to be safe.
Manual Brake Booster Rod? Conversion for 65 Barracuda
Many use the Dr Diff package, which leverages a later Dodge truck MC. I recall a version with a smaller custom bore. But some prefer the old crusty cast-iron with leaky cap. Mopar Aluminum Master Cylinder Kit
For a conversion to front disks, most people use a proportioning valve. If not, the rear wheels may skid first, to cause loss of control. I put a new adjustable prop valve in the rear tubing in all my old Mopars. Adjust in a wet parking lot until the fronts skid just before the rears. I kept the OE distribution block, but just as a tee for the 2 front wheels. Plugged the rear port (inv flare M plug) and put a 3/16"F to 1/4"M inv flare adapter in the top port from the MC (F port, at rear), all fittings in bubble packs at Autozone.
