Oh I also checked earlier after going and seeing/picking out our new puppy. No lines are leaking and no lines appear to be crimped. So that's good
Have you bled the brakes again?
Tomorrow. I got home later in the evening, then hung out with the family before putting the kids to bed. Im going to do it first thing in the morning.
Are the rear shoes new, and installed in used drums?
I suggest pulling rear drums, pry e brake lever back to make sure its in its proper resting point. then adjust brakes.
When bleeding, which corner(s) had air?
I agree with the above. If you want that "last little bit"......and I would, look at the rear. Clean and adjust them. But make sure the parking brake cables are seated good first. The rear can make a significant difference in pedal height. Really simple to do. After you get the wheels back on from cleaning everything up and seating the brake cables, simply adjust the brake shoes on each side so that there is decent enough drag on the wheels that you cannot just "spin" them freely. As you're getting close, make an adjustment, beat on the tire. Make an adjustment, beat on the tire. Pounding on the tire like that settles the shoes back down and gets all the slack out of them as you adjust them against the drum.
Looks like a little too much for my liking.Oh I forgot pictures of the pedals. Here they are. Pedal up and pedal pressed.
I will read through the FSM and try to get the e-brake adjusted "properly." Right now I can only slightly spin the wheels, maybe 1/5 turn when I spin them and I hear the drums dragging slightly.
Brake fluid is non compressible, two pumps could be excessive shoe travel.
Yea I like where it stops at the double pump spot, so maybe ill adjust the rear drums some more. When I do that I have to rebleed the brakes yes?
Pull drums off first. Inspect park brake linkage.Yea I like where it stops at the double pump spot, so maybe ill adjust the rear drums some more. When I do that I have to rebleed the brakes yes?
If it will help, a camera...ok .... what am I looking for?
