dusterbd13
when the time comes, you could probably cut out a 1/2 inch out of each leg of each bumper bracket, weld back together, and then set depth with a shim pack. ive done that before.
I have heard that you can also heat and bend the linkage down to clear the header pipe. Probably not too much or it will throw off the geometry.
Just a little tap tap....
Happy Gilmore in case you missed it Alex.
HOLY CRAP! Alex,you have come a looooong way with your Dodge. And you're still married!
Congradulations...
