FABO'ers:
I know Comp Cams recommends an initial run-in without the inner spring on all their cams using dual springs. Is it really necessary on a small cam? I plan on using the XS282S (244/[email protected], .52/.54 lift) and the recommended 986 springs (322 lbs/inch).
Thanks.
Thanks.
