zigs
If the seats your using are not stock buckets thy probably won't line up. If your seat are from a B- body c -body ,the seats will be longer and a little wider. Get your backing platers as mentioned above. Get them lined up tack them, set your drivers seat first line the middle of the seat up with the center of the steering wheel, mark placement on plates. Take seat out make sure everything is square. Also good idea to check glides make sure seat is where you want it. recheck measurement maybe put the seat bact in . If your satisfied, pull the seat drill the holes.
