Have been wanting an Engine Run Stand, so time to get to building one.
Are you going to provide any engine front support?
Thanks, unless it is jacked up enough to get the wheels off the ground, it will take off across the garage floor.That is a nice picture of your design there, like how you did that.
Weld a couple of capture plates on the legs at your stand, drill horizontal holes and run a bolt through to secure.
Love the idea of breaking it all down to a set of tubes leaning against the wall. Normal run stands take up a ton of space. A buddy has one hanging in the rafters of his garage!
I just realized i have a manual trans bellhousing,that might fit the bill for a run stand. Will an auto torque convertor fit in there i wonder?
The flywheel is off a poly engine so it wont work.
Different bolt pattern.Is the Poly a Neutral Balance 130 tooth flywheel? If so and it bolts to the crank then can use for 318s.
Neutral balance flywheels can be used with the external balanced 360s too with one of these Balance Plates I got from Summit.
I admit it, I"m a redneck LOL. Did this for a quick engine fire up and test. Carb adapted to a Magnum LOL Ignition is an GM HEI in the box with an old coil mounted, and some "clip" leads. Front of the engine blocked up on wood and blocks
LMFAO Anybody figure out what this is?
Guess i could visit machine shop with my flex plate and flywheel and get it drilled. He likes a challenge.
Im not dumping a bunch of money on what i would call a prototype. Then i dont feel so bad if its a failure. And its my thing, repurposing otherwise useless stuff.I like that thinking . . makes this stuff fun, figuring out how to make things work with what you have available for parts.
I was thinking about the automatic torque converter as an option too, but there is no support for it for where it would go into the front transmission pump. Would be dangerous running that heavy converter hanging just on the thin automatic flex plate.
I would say no, want to play it safe.
Got an old furnace fan, that will chuck enough air.couple of box fans on a table, boxes or chairs... They re-purpose easily
I wouldn't go all fancy on electric fans on the stand radiator. Hillbilly all the way!
