Charlesvolare
Not yet, but that's the plan eventuallyAre you hitting this thing with a bottle?
Since I first out it together it's been through a Mopar cam that ate a lobe, a comp 268h grind, a comp roller it has now. Went through and put in a set of bearings after the first cam. A few sets of head gaskets before I finally got the heads milled flat. Two 904's, a rear end, at least three sets of rear tires. Foot on the floor a good 80% of the time. I drive it hard and it's been through a lot.
