yellow rose
Overnight Sensation
@Yellowrose, your concept about the t-stat setting the minimum temperature is basically correct. But your numbers don't work out if the shop manual is correct, and I think you are wrong to dismiss it. The thermostat openings have a plus minus of 5 degrees to crack open enough to get a feeler gage in. Full open is around 20 degrees hotter - plus minus some. Surely you're not saying those shop manual specs are incorrect.
This is what my post was referring to.
Also when tech goes out of their way to say that the 1968 Chrysler system does not pressurize due to coolant expansion, then someone says that cooling systems pressurize due to liquid expansion; that person either didn't read the explanation, or doesn't believe Chrysler knew how their own system worked.
Now, why run a hotter rather than a cooler engine?
On a low compression street setup I would give two reason:
1. To get rid of the condensate in the engine, especially the oil.
2. To more completely vaporize the gasoline.
Now that second can be argued about. I don't have numbers or test or any of that. But this is what Shrinker was always writing about and I buy it. When we set up relatively low compression situations we need to get enough heat in the chamber so light and medium portion of the fuel vaporizes and distributes evenly before spark.
On some engines this isn't going to apply because the heads, piston and cam are doing the work. So on some engines more heat could hurt. I get that.
The opening point of the thermostat depends on the manufacturer. The Stewart Components thermostat is fully open by it’s rated temperature. That’s why I keep saying there is a difference in thermostats. If you have a 180 degree thermostat and it’s not fully open until 200 degrees it’s junk. That means the rated number doesn’t set the minimum operating temperature. It’s basically a guesstimate.
1. I agree, but I will say this. The oil temp isn’t much lower if the coolant is 180 than it is if it’s 200 degrees. IMO, short drives is what keeps the moisture from being cleaned up.
2. I also agree, with a caveat. Any time the intake manifold is heated with exhaust gas, coolant temperature means very little in vaporizing the fuel. The exhaust gasses are much higher in temperature than the coolant ever will be.
