68- 74 318 heads, casting # 2843675 is 60cc
AdamR said:after 71 they dropped compression by moving the piston pin up. this dropped the piston way down in the bore about .100"
The earlier 318s that are rated in the 9:1 are are lower then that. probably in the *.5-8.8:1 range.
The real bad news is your 318 is likely in the 7.8:1 range.
The only way to know for sure what your compression is ,is to measure everything. Head CC's, Deck hieght and gasket thickness.
AdamR said:they will have a few differances but for the most part they are the same.
I would have a set of heads milled about .050" and run a thin .028" gasket.
Nice Dart by the way.
AdamR said:The intake will fit fine. When you mill the heads they will mill the intake side of the heads also. You will likely need shorter push rods.
Sublime69 said:All im trying to figuer out is how much will the compression will go up if i but magnum heads on my stock 74 318.
