- Joined
- Mar 6, 2008
- Messages
- 1,140
- Reaction score
- 825
I read the write up of putting the GM module in the ignition. Is that the same for any Mopar engine?
It's the same for pre-Lean Burn slant sixes, small blocks, and big blocks. I've heard it's also the same for Australian hemi sixes. For other engines, you would have a bit more difficulty.
Say I used an MSD 6A box, would that negate the need for the resistor and ECU? Or does the box simply amplify the signal that's sent out by the ECU?
The box negates the nead for either one. It can trigger off the pick-up coil in the stock distributor and bypass the rest of the system.
