[FOR SALE] Charging system wire around 6 or 8ga
Mopar Exterior Parts For Sale
Thread Status:
Not open for further replies due to lack of activity. Consider opening a new thread instead.
  1. crackedback
    crackedback FABO Gold Member FABO Gold Member
    18,562
    2871
    Aug 7, 2005
    92201
    Local Time:
    12:46 AM
    Contact Seller
    Charge system bulkhead wire around. The idea is to remove the bulkhead connectors and resistance in the circuit from the charging wires. I have two set ups available. One is 6ga wire with 10ga fusible link, the other is an 8ga wire with a 12ga fusible link. The 8ga wiring solution would be OK for alternators up to about 90 amps. The 6ga would be OK to about 120 amps in most situations. Most of the time the alternator is not providing maximum output. I do my best to make the wire black from end to end. I can place red shrink at the ends to remind that it is a hot + wire.
    Example of the 6ga wire used. It's great wire that is very flexible and hides nicely in the OEM harness tabs..
    6ga example in red. I no longer use the red wire for this item.
    8ga wire around
    I use as much US sourced wire as possible. It's getting tougher to find US sourced fusible link.
    Wire set ups are $30-40 depending on length + shipping from Indio, CA
    I do provide discounts for customer loyalty and multiple items purchased at same time.
    PM here or email to robule1 at yahoo dot com
    Thanks for the ad space.
    Rob
    • Like Like x 1
    • 318MoparGuy
      318MoparGuy MoparHokie
      249
      77
      Jun 27, 2013
      Waynesville,NC
      Local Time:
      3:46 AM
      I did the 8 gauge with fusible link on my 73 Dart Swinger and it really took the electrical load off of my headlight switch and bulkhead connectors. Rob really does excellent work and uses quality materials in the construction of his wire arounds. I highly recommend this upgrade to your electrical system for all our Mopars. I also purchased Rob’s headlight relay kit...a very easy plug and play install and the headlights on the old girl are much brighter and no dimming at idle. I wish he made more products for our cars and he stands behind all his stuff. A great FABO member!!!! THANKS ROB.
      318MG
      • Like Like x 3
      • crackedback
        18,562
        2871
        Aug 7, 2005
        92201
        Local Time:
        12:46 AM
        Thanks for the positive comments and great to read it's performing to your expectations. Appreciate the patronage!
      • Heywodja
        Heywodja The Heartbeat Stops Here. FABO Gold Member
        510
        153
        Aug 16, 2014
        Texas
        Local Time:
        2:46 AM
        Does this eliminate / bypass the ammeter?
        I really like the battery cables you made me , I have one of those power master alternators to install and I will be running a efi setup too.. is the 8ga the way to go?
      • crackedback
        18,562
        2871
        Aug 7, 2005
        92201
        Local Time:
        12:46 AM
        It is part of bypassing the ammeter.
        Depending on Amp output of alternator. I'd run a 6ga for anything over an 75-80 amp unit.
      • famous bob
        famous bob mopar misfit FABO Gold Member
        16,614
        6389
        Aug 14, 2011
        okla
        Local Time:
        2:46 AM
        Sounds like I need to go to a heavier wire !
        I dont have any trouble w/ anything , except hot starts , never starts on the first turn of the key , but hit it quick a second time and it fires up . ??????????????????
        any ideas ? Been this way since day one , scares me , but hasnt failed me yet .--????????????
      • Heywodja
        510
        153
        Aug 16, 2014
        Texas
        Local Time:
        2:46 AM
        I will message you for cost
      • famous bob
        16,614
        6389
        Aug 14, 2011
        okla
        Local Time:
        2:46 AM
        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ANYONE ??
      • crackedback
        18,562
        2871
        Aug 7, 2005
        92201
        Local Time:
        12:46 AM
        The wire around doesn't do anything for starting the car.
        Maybe larger cables on the starter? That could help if it doesn't crank easily, both pos and neg.
        @famous bob
      • famous bob
        16,614
        6389
        Aug 14, 2011
        okla
        Local Time:
        2:46 AM
        WAS THINKING THAT ALSO ------THANKS !
      • barracudadave67
        barracudadave67 FABO Gold Member FABO Gold Member
        1,162
        482
        May 22, 2004
        Burlington, Wi.
        Local Time:
        2:46 AM
        PM sent
        Dave
      • 65Val
        65Val Average Length Member
        5,070
        1042
        Oct 14, 2005
        Victoria, BC, Canada, EH!
        Local Time:
        12:46 AM
        Rob...where does this actually connect in the car ('67 Dart)...I'm a total idiot when it comes to auto wiring (actually hate it!), so can you explain what this does, and where it goes, to me in dumb-speak please? Thanks!
      • crackedback
        18,562
        2871
        Aug 7, 2005
        92201
        Local Time:
        12:46 AM
        @65Val
        Connects at alternator charge stud and starter relay stud.
        Carries the majority of any battery required amp charge load. Takes that load off the bulkhead, normal charge path back to battery.
        • Like Like x 1
        • 65Val
          5,070
          1042
          Oct 14, 2005
          Local Time:
          12:46 AM
          OK, thanks Rob...that makes sense to me.
        • crackedback
          18,562
          2871
          Aug 7, 2005
          92201
          Local Time:
          12:46 AM
          No problem. Have plenty of materials for both 6ga and 8 ga set ups on the way.
        • RustyRatRod
          RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
          60,900
          32599
          Jun 7, 2010
          Georgia
          Local Time:
          3:46 AM
          Rob, can this be used while keeping the bulkhead connector and ammeter they way the came? Is there any benefit?
        • crackedback
          18,562
          2871
          Aug 7, 2005
          92201
          Local Time:
          12:46 AM
          This renders the Ammeter inefective. You can leave the ammeter if you like, I always bypass it.
          I always suggest leave all the OEM wiring in place and bypass ammeter.
        • RustyRatRod
          60,900
          32599
          Jun 7, 2010
          Georgia
          Local Time:
          3:46 AM
          Well mine actually WORKS, so I am leaving it be until it doesn't. I've inspected the firewall connector and it looks fine. Course this car is all stock so there's "that".
          • Like Like x 1
          • QuickDart360
            QuickDart360 Well-Known Member
            1,150
            406
            Apr 5, 2014
            San Antonio
            Local Time:
            2:46 AM
            Cool! So you installed wire bypass and ammeter still works? I am strongly considering doing this for peace of mind in my dart sport soon! So you just added this without modifying anything? If so I like this idea even more!!:)
          • barracudadave67
            1,162
            482
            May 22, 2004
            Burlington, Wi.
            Local Time:
            2:46 AM
            On my 69 B-Cuda, all I did was connct the wire to the alternator out put wire, (the big terminal) followed the wires over to the starter relay, and connected it up there. I had already bypassed the amp gage. Headlights do not dim.
            Installation took 1/2 hour.
            Dave
          • RustyRatRod
            60,900
            32599
            Jun 7, 2010
            Georgia
            Local Time:
            3:46 AM
            No I was saying my ammeter is a good one. It works now. Since it does work, I am not going to get the bypass wire.
            • Thanks! Thanks! x 1
            • crackedback
              18,562
              2871
              Aug 7, 2005
              92201
              Local Time:
              12:46 AM
              Thanks for the purchases and I have plenty of materials right now for kits. Both 6 and 8 GA.
              Rob
            • RustyRatRod
              60,900
              32599
              Jun 7, 2010
              Georgia
              Local Time:
              3:46 AM
              Since you brought this back up to the top, I have a question. Forgive me if I've asked before, my forgetter works full time now. Is there someone who converts these ammeters to volt meters? I don't give a crap if it reads numbers. I can relate to it with the "D" and the "C". I'm just wondering is someone can basically stick a volt meter on the back of the stock face?
            • crackedback
              18,562
              2871
              Aug 7, 2005
              92201
              Local Time:
              12:46 AM
              Yes, redline does it.
              Lots of home builder guys have used some of the small voltemeters and installed them in the original clusters. If you search here or FBBO, there are some threads on the process.
            • QuickDart360
              1,150
              406
              Apr 5, 2014
              San Antonio
              Local Time:
              2:46 AM
              I have a question. Mr heaterbox another cluster/gauge restorer claims that they fireproof the ammeter gauge. In a pic they solder/sauter the threaded studs so there is no threat of fire according to them. Is this something that sounds reasonable or better yet believable?
            Thread Status:
