On the bright side, all the hammering helps work off the frustration of needing to hammer.
I have them in my 67 as well, the key is a decent front tire height and a rebuilt suspension, I can’t image the car getting that low on a dip to compress enough it hit. Now I use to have them on a worn out a body front end years ago with a 225 60 14 tire that was a bad combo for front end and header clearance lol
Putting dents in headers does affect the performance of the headder.
oh really?
review the evidence here and get back to us on your thoughts.
maybe you need to go watch it again and refresh your memory. the amount and degree to which they dented those tubes up far exceeds any amount i've ever had to massage a header in order to get it to fit, and i'm sure it's the same for most others.I Seen that video long ago and I disagree with it. You put enough dents in a header tube and if they are deep enough it sure does affect flow. The best way to avoid having to beat on headers to begin with is to buy a quality header such as Doug's or tti's.
The cheapy headers create plug wire issues as they are right next to the plug wires and also makes it harder to change the plugs. I've also read about the header tube being close to the master cylinder has been known to raise the temperature of the brake fluid. I've done alot of research on things probably more than othersmaybe you need to go watch it again and refresh your memory. the amount and degree to which they dented those tubes up far exceeds any amount i've ever had to massage a header in order to get it to fit, and i'm sure it's the same for most others.
and what was the outcome? that's right, nearly nothing.
again, you're over here speaking like you're an authority on the matter when you don't have headers and don't even have a car.
i'll agree to the point that buying quality pieces like doug's or tti eases the install process, but as OP showed, even the cheapy summit units don't require mangling if paired with the right combo of parts.
yes, but how many have you actually installed? how many cars have you had with headers? how many cars with headers have you worked on?The cheapy headers create plug wire issues as they are right next to the plug wires and also makes it harder to change the plugs. I've also read about the header tube being close to the master cylinder has been known to raise the temperature of the brake fluid. I've done alot of research on things probably more than others
TV personalities, sponsors and property damage aside you can't really ask for more of an A & B testAll BS aside I really don't trust TV personalities who are paid to destroy things and get sponsored as a real world test.. Dyno's are just that a perfect world scenario. Any Header can be made to fit, and any combo can have challenges it is sometimes or many times of the IDT10 variety..
Headers are for me, very much so. It's just that I'm going to buy what fits, I'm not a hammer mechanic. I've seen people have a custom made high pressure line for their header to clear. Also poor motor mounts can cause fitment issues.yes, but how many have you actually installed? how many cars have you had with headers? how many cars with headers have you worked on?
research all you want, there's no substitution for real world experience.
also, sounds like headers aren't for you.
Simple little polished shield under the master cyl addresses any heat concerns you might have.The cheapy headers create plug wire issues as they are right next to the plug wires and also makes it harder to change the plugs. I've also read about the header tube being close to the master cylinder has been known to raise the temperature of the brake fluid. I've done alot of research on things probably more than others
What's the best horsepower with manifolds
I agree. I really want to get me a car here really soon and I believe that with what I'm going to do with the car that manifolds will be fineThat depends. But the correct answer is 85% of the guys on here are just cruisers and power doesn’t matter to them.
That’s who should be running manifolds.
I’ll say this again. A header that drops right in and bolts up is most likely a header that won’t make much of a power difference.
On Chryslers you are double screwed. If you have power steering it limits what headers you can even get on there.
And then, because we are all getting old and this **** is drying up you can’t even buy a good header any more.
They stopped making them. So now you are down to paying new prices for used headers.
And that’s IF you can find them and IF you don’t have power steering.
As for the Engine Masters test, an engine dyno like that does NOT measure an engine’s ability to RPM.
I’d suggest on a different dyno or in the car at the track, those smashed up headers would get their *** handed to them.
Getting ready to make a road trip to look at a 1970 dart. 360/904/8.75. Has ac and ps, it's clean $22,500. It's a 4 hour trip but I think that it's worth it.I agree 100%. Manifolds will be fine for what you want.
i'll believe it when i see it Dan.Getting ready to make a road trip to look at a 1970 dart. 360/904/8.75. Has ac and ps, it's clean $22,500. It's a 4 hour trip but I think that it's worth it.
I'll be kinda hard for you to see it with you living in the uki'll believe it when i see it Dan.
Thanks, I really appreciate it. Will have cash in hand as cash is king. Having a good friend go with me and will be towing a trailer tooMost of us on here are rooting for you Dan.
Let’s hope this works out for ya.
Update us when it happens.Getting ready to make a road trip to look at a 1970 dart. 360/904/8.75. Has ac and ps, it's clean $22,500. It's a 4 hour trip but I think that it's worth it.
