I've yet to drive my car but I have re-drilled axles on my 408 powered Dart. I used B body drum brakes which required this adapter that I made. I'll find out soon if it's strong enough.
why is everyone over looking the simple wheel adapters?
Because most folks would rather not use wheel adapters if there are better options.
I thought about that but the cost to make them is too high. I had to machine them on a CNC mill because our lathe is setup for small diameter parts 100% of the time. I took me over 5 hours to make them this way.
why is everyone over looking the simple wheel adapters? he said its not high horsepower and doesnt plan on making it that way, so why not just find a pair of thin wheel adapters? by the time you get axles redrilled add new drums and pads and seals and other misc. parts your talking some cash. adapters are probably around $100 or less for the pair and are no harder to install than just taking the wheel off.
i understand there are better options but he asked about the cheapest way to get the larger pattern and ballistic fabrication sells some tough billet ones very reasobably priced and if they dont have the one you need im sure they wouldnt hesitate to make it to your specifications for a few dollars more since they do custom work all the time
I took a look at a 7 1/4 axle, today. There really isn't enough meat to just redrill the flange for the LBP. As another poster stated the hole in the flange to remove the axle flange nuts i the main problem. It really should be filled, then you have no convient way to remove the nuts.
Best to just get a LBP 71/4 "A" body rear.
Look for a usable '73-'76 BBP A-body axle. Most people just give 'em away or don't want much for them, unless they are packing a LSD (freak of nature, and yes, I do have one in my shed). Do a fresh set of axle bearings and seal and be done with it
Thats why i suggested the cnc machined billet ones made by ballistic fabrication. Not trying to be pushy on them just suggesting becuse you said youve only seen thr cast version which i myself would be leery of to. But they run their spacers on high tourqe rock crawlers and desert race trucks so i wouldnt worry one bit about their quality
It seems like the wheel adapters aren't that bad of a choice as long as you aren't taking them racing. I'm in the same spot upgrading the front to disc but will wind up with mismatched wheels for a while. To skip that headache I'm gonna try these adapters on the back for now. Not a long term fix but it seems like it'll do on my 7.25 rear. Anyone hear of the wheel adapters failing or found any other evidence why they should be completely avoided?
