Assembly line correct for dart swinger.
I think the conversation is informative to members and potential buyers.Wow, take this information to a private conversation, back and forth comments and opinions are smothering this for sale thread, if the OP seller wants to start a new sale thread let me know, I will delete this sale thread if he elected to start a new one.
The tip on the left is for a 68-70 charger. I had those alsoTip on left is for 68 69 Barracuda. Tip on right is 70 swinger. Left Tip is for big block (and yes it's for sale..only have one). See the different angle on Barracuda inlet. 70 swinger Tip is one year only. Barrel part of tips is also different length.
You may be correct about the tip being for a charger.The tip on the left is for a 68-70 charger. I had those also
So they are the same. Good to know. Increases customer base. Looks like dodge did use the plymouth tip for 1970.
Yep. Sames as all the tips that are here. For A-body cars with a rear valance including Dart. There was never a bend in the tip to face them upward. It was in the tail pipeFrom my '69 Barracuda I've had since '80....................
Couple more if it helps........
The charger tip confused me. That one does have different inlet angle. See pictures.Yep. Sames as all the tips that are here. For A-body cars with a rear valance including Dart. There was never a bend in the tip to face them upward. It was in the tail pipe
Are you sure you weren't using them as wheelie bars. LOLFWIW, both of mine appear to have a slight angle to them..............
Then there's this............
[/URL]
