Close as you will come to getting an OEM fuel sender..
The full tank resistance is closer to 74 Ohms. So 80 isn't awful.
Maybe it also matches the later fuel gages @RedFish mentions in this post: Gauge Cluster Issues/IVR
@toolmanmike This shows the internals and more
Thermal-Electric Gauges (Session 227) from the Master Technician's Service Conference
Per Stewart Warner specs, these are 80-10 instruments. 80 ohms = no needle movement. In the case of fuel gauge, 73 ohms will lift the needle to the first/empty hash mark. The tester used by service techs had less than 80 ohms for starting point because 80 or greater ohms would not have been a test. 80 or greater leaves you scratching your head, "Does it work or not?" I hope that makes sense.
Half range is 23 ohms. Calculator says half way between 80 and 10 is 45 but that's not how a thermal resistor instrument works. As a thermal resistor wire heats up its per inch resistance changes. Max range is 10 ohms.
Don't mean to hijack the thread, just some info that seemed relavant.
A couple of years ago I found a NOS Mopar sender for my Dart. It was a Mopar made (contracted) sender part number 4051 003 (build date? 0997?) (from my previous thread i have the part number as 045041004? Typo maybe?)
When I installed it I tweeked the up stop as I came to find out, too much, as it would peg the needle when the tank was full.
So today I decided to pull it and make an adjustment.
Well for craps sake... the float has some fuel in it.
No one has one in stock so I have to wait till tomorrow and hope the only one I could get is close enough to the right diameter.
This is full on the sender now
Also this is the best I can do to get it to read empty
I'm really hoping that the A 100 sender in this post proves to be a better sender for us all.
This is with a 10.1 ohm (100W) resister in place of sender
18.3 is 3/4
25.5 Is 1/2 (ran out of photo up loads)
47.2 is 1/4
This is with 80.5 ohms in place of the sender
This is with 83.5 ohms in place of sender
85.5 ohms from driver's perspective is dead nuts on empty
I added my resister values to my previous Threads graph (red triangles are Empty, 1/4, 1/2 and full on the gauge) I wish I had a 67 sender to compare :(
As far as I know,OEM senders never had a plastic float.
This is an OEM sender, came in Mopar packaging, but made in the 98. I bought it from a Dodge dealer in Georgia (IIRC), I was told it was the last one in the Mopar parts system. I have a post about it and the part numbers that it supercedes.
