clutch recommendations
justcuz
what clutch package would u recommend
for a 70 Dart Swinger
340 4 speed?
I`m experimenting with centerforce dual friction. It has`nt been in too long, but so far so good.--- I just finished up installing one in my 1 -ton work Rig. That will be a true test. :clock:
borg & beck in my dart.
need both feet to push it down.
dont like it.
I have had great success with the McLeod 10.95 (11") diaphragm pressure plate and clutch. Very street friendly and has track action when needed. You remove the overcenter spring with all diaphragm pressure plates.
http://www.brewersperformance.com/
Ask for Wayne.
I,ll second the CenterForce dual friction clutch,you can remove the overcenter spring and save your left leg at the lights.I,m going on my 3rd year with mine and punish it pretty good with no problems.There a bit pricer than the rest but worth it IMO.
In both my Dodge Cummins and also my Dart...I run a South Bend. Dual friction in the Dart and a dual disk 12 ceramic puk disks with 3250 clamp load..
Nice..
