I`m experimenting with centerforce dual friction. It has`nt been in too long, but so far so good.--- I just finished up installing one in my 1 -ton work Rig. That will be a true test. :clock:
I have had great success with the McLeod 10.95 (11") diaphragm pressure plate and clutch. Very street friendly and has track action when needed. You remove the overcenter spring with all diaphragm pressure plates.
I,ll second the CenterForce dual friction clutch,you can remove the overcenter spring and save your left leg at the lights.I,m going on my 3rd year with mine and punish it pretty good with no problems.There a bit pricer than the rest but worth it IMO.
