I was at a show this past weekend and although the Mopar crowd was scarce compared to the other manufacturers they did represent well.....I saw a beautiful 69 Road Runner that was an automatic on the column originally and was advertised as a 440. Not sure if it came with it or not but it was a good looking car. The issue I had was something I think would take a mechanically inclined person less than an hour to fix. Although it was an auto on the column it had a floor ratchet type shifter installed. The gear selector was still in place in the column along with the indicator for what gear you are in. To fix it right the column should be replaced but for c'mon man......at least remove the column gear selector.
