Coil and ballast resistor
gliderider06
Delaware
What coil and ballast resistor should I run with electronic ign orange box. I have .5 and 1.2 ohm ballast resistors and uncertain whic one is the one to use. I have a Standard ignition coil, and an Accel Super Stock coil, but I was thinking about buying a MSD blaster 2 coil. I think it makes a difference which ballast to use depending on coil, but very uncertain. Can someone steer me in the right direction.
Thanks!
MSD Blaster 2 comes with its own ballast. IIRC its the .5 that it uses. Sorry cant help you on the Accel other than I ran one on a 70 D100 I had with the factory ballast and no issues.
